I have a 1971 55HP Chrysler. When I adjust the gear rods in LU. The best I can get is it will go in Forward and reverse with it reving. Thats what happens when adjusted centered. I can adjust it to go in forward smooth without acceleration but then it won't go in reverse. I can do the opposite also. I removed LU again to check measurements and it is correct. (1/16) Tried adjusting cables to see if that had anything to do with if, but to no luck. Thanks
