Found some rocks with my prop...
jimmbo
That Number(0522) stamped on the Hub, is likely a Repair Work Order #, and the Prop looks like it has been repainted
tpenfield
What worked in the past has a good probability of working in the future. I'd get the same prop and call it good.
nola mike
Bought it new from Amazon (not 3rd party). The lovely paint job is mine after repairing. Guess it could be counterfeit or misrepresented
airshot
Coming from Amazon.....who knows who made that prop and where it came from ? Over 65% of items from Amazon, never touched an Amazon facility. Most item are shipped from the actual supplier using Amazon boxes and advertising for a commision.
airshot
The only time I tried to bench true an aluminum prop the blade I was straightening cracked. Aluminum doesn’t like to bend and, unlike steel, has no memory of where it was.
The last time I asked a boat dealership if there was anyone in the area working on props I got 3 phone numbers to try.
Heat helps when rebending aluminum....
Scott06
I'll do some bench side truing, but the prop is only $110 new and again, I don't even know who would do it around here. The pita factor isn't worth it. Wondering if I should buy another identical prop or go with something SS/fancier, if any gains would be worth it. This prop pulled my old ass up on a slalom ski the other day with 3 aboard, definitely better than the 3 blades I'd used
If you got one you are happy with get another.
prop MD in MN does mail order repairs if you want a spare
