Silvertip
- Joined
- Sep 22, 2003
- 28,771
Yesterday I had my boat in a shop getting a re-power done. I was keeping an eye on the tech doing the work but my attention was drawn toward the back of the shop where a group of engine blocks was neatly arranged. I managed to get a closer look and counted 18 four stroke blocks with varying degrees of ventilation. Two failures were most evident. 1) rod through the block and 2) hole in piston from swallowed valve (probably from broken/slipped timing belt). Most were three cylinder engines but I also counted three twins and three V6's with similar problems. Further checking revealed five other engines. These were two-strokes and judging by the amount of gunk and grime on them, were at least 10 - 15 years old or more. I quizzed the tech and the owner but both were very tight lipped and offered no explanation other than "things break". Glad my repower is a two stroke.
