Greg Mrozinski
Ensign
- Joined
- Aug 17, 2009
- 941
Re: Frak.....cut through my hull with a reciprocating saw
Yeah I know. Same here.
Gel paste alone for any repair will eventually fail. You need to spray it ( to encapsulate from water intrution ).
Myself I would
1. prep the cut area about 6" around the cut. ( inside )
2. Die grind the cut inside to bevel the hard edge off.
3. fill the cut with "mohair" ( poly resin,cabosil and shaved up chopped mat ).
4. without delay lam with 1 layer of 1.5 oz mat and 2-3 layers of 1708.
5. after cured goto the outside and bevel-grind approx. 3-4 " around cut ( you should have a smoth surface now because the crack is allready filled with mohair from the inside ).
6. lam the outside with 3-4 layers of 1.5 oz mat.
7. sand/fair.
8. fill pinholes with poly glazing putty ( do not use the putty to fill lows ).
9. final sand/fair with 80 grit on repair.
10. prep area around repair with 180-220 grit.
11. spray gel-coat with preval sprayer.
12. wetsand and buff.
Good as new.
YD.
PS. Remember that my suggestions or opinions are how I do them. Its not my boat and have the peace of mind knowing when the job is done its done right for the life of the boat ( untill the guy hits the next channel marker).
