I built a boat several years ago from a bare hull. It is a 2001 21 Larson SEI. It was completely stripped when I got it. It originally set up for Volvo drive,which was missing, so I replaced it with a Alpha. The motor itself runs great, but just doesn't have the performance I feel it should have. I know I am just putting out 200 hp, but it feels like more of an outdrive issue. I can only trim up for a second or two before you feel the prop loosing bite. Same thing when you make a sharp turn you just feel the boat stop pulling. I was able to bolt the alpha drive in the existing Volvo holes, so I don't know if it is set up correctly. Any suggestions?
