Free Boat, This thing is a badboy!
gazza2007au
Hey guys has been a really slow summer no progress but i will get up to date with pictures of the transom, now it is almost winter her in Australia progress is resuming slowly i am now just finished grinding down the stringer tabbing and sanding a area to glass to i also picked up a 90hp Mercury 4 Stroke i think you guys call them VERADO's but this is non turbo
basically this update will skip many pictures but it will get u up to where i am today
i learnt the hard way and used epoxy resin with talc mix as fairing it was incredibly hard to sand flat
lots of pictures guys pretty much showing each step
kcassells
Talc absorbs water...…...…...……...…...………...…………………...……….
gazza2007au
Nice and cool here but winter hasnt arrived yet
i put two layers of epoxy over the talc mate
gazza2007au
Yesterday i finally finished grinding down the stringer tabbing and today i swept and vacuumed up all the dust now i need to put two pieces of 2x8 under the hull as a jig to make sure the hull is not hooked before glassing commence
i have one stringer made the main keel stringer but it started to go a tiny bit moldy with black mold so i used some white wine vinegar to try remove it it slightly worked i will sand the rest off, all stringers will be given 2 coats of epoxy before being glued into place
gazza2007au
That'll help. just keep an eye on the transom. :D yea were just getting spring/summer here.
When its Summer here i absolutely sweat my nuts off just looking at the boat LOL our Summers reach 50C thats 122F the luxury of living on the worlds biggest island haha
gazza2007au
Got a little plan in place done a drawing i am going to focus on rebuilding the boat as a cabin boat the new cabin will be made from 7mm or 9mm plywood glassed with one layer of knitted biaxal and one layer of woven roving both inside and out, windows will be tinted persex
gazza2007au
Started building the hard top canopy trying to make the boat look like a Surtees or a Bar Crusher lol
archbuilder
So I am assuming you will be laying glass over the top of the plywood or will you be using it as a mold of some type?
gazza2007au
Yeah i will be glassing it 2 layers on the outside and two layers on the inside i am contemplating using carbon fibre but the other option is regular biaxle 45 45 and woven roving and epoxy resin
i bought some 40x18mm wood today to reinforce the plywood with internal framing but its medium density board and not pine as i wanted so it just means i need to look after it as its MDF and not pine however it will be encapsulated with epoxy resin
sphelps
Be careful with the hull just sitting on those rollers . With no stringers the hull will flex easily then when you glass back together your hull will be permanently crooked. Especially with adding the extra weight of the hard top ...
You can temporarily shore it up with some 2x’s to make bunks and brackets fastened to the trailer.
gazza2007au
Hey Sphelps, i am going to raise the hull by jacking it up and placing long pieces of 2x6 under the hull before i start glassing the stringers in just haven't gotten around to picking up the timber as its 5meters long thats about 16 foot long timber i need to cart around on the car roof
Tassie 1
What happened to the original cabin?
l have to agree with the oz local yokels who think 7mm plywood is too light for what you are thinking,
too much flex, long term durability is suss,
also to my uneducated eye the height of yor proposed cabin looks to be too high, at the very least aesthetically anyway,
windage could raise it's head as well
l've seen several fg renos locally with high modified cabins on older fg hulls like yours but rarely out on the water, usually in the front yard with a for sale sign and they dont sell in a hurry
Sounds negative l know but if l were you l would drop the height a tad and user thicker ply,
we will be using 12 mm ply at least on our gunnel and cabin repairs shortly,
but it is your boat....
just my thoughts
cheers
gazza2007au
Hey Tassie no floor in boat yet mate so i was only guessing a height, from the old floors outer edge inside the boat to the gunnel is 600mm from the gunnel to the bottom of the windscreen is 600mm from here to the roof is 600mm so from the floor to the roof its 1800mm i'm 1670mm tall i like to stand up and drive i may being the roof down a tad bit but undecided yet
the plywood is 7mm to keep weight down its mostly a skin i have internal bracing there shouldnt be any flexing due to the inner framing
gazza2007au
Glued in the main keel stringer yesterday but having problems filletting using 2 part epoxy adhesive also known as epoxy cream, the cream is flattening out and running down on to the hull the glue cost $150 for 1 gallon (4 litres) quiet an expensive experience
from here on i will pick up a free bag of sawdust and mix it with my 5 to 1 laminating resin
gazza2007au
Here are a couple pictures marking the current lines on the boat and how it should look finished
