Freezing
Darrendude
I am in central Calif. It is getting cold at night this time of yr. Do I need to be concerned if the low is 31? Im sure its only 31 for a couple hrs, is that enough to cuase damage? It warms up to the 60-70 in the daytime.<br /><br />Thanks
KaGee
Re: Freezing
Takes a real cold snap to freeze a block..I would not worry about it out there.<br /><br />Now here.... with wind chill just above zero at the moment....
Re: Freezing
8* Below in the shade here, at the moument.........<br /><br />Darren,<br />It takes about 4 to 6 hours at 28*s to Crack your Block.......<br />About the same amount of time at 30*s will Crack the Exhaust Manifolds.........<br /><br />I Doubt you'll be having any Problems.......
