fresh VS salt water prop
rbh
Due to the density of salt water as compared to fresh water, what course of action if any is required going from one to the other?
thanks
rob
Re: fresh VS salt water prop
Ayuh,... Prop wise,... Nothin'....
Even though the prop gets a Better bite, the hull also floats higher,+ is more efficient...
My barge pulls 42/43mph at 4800rpms here in the Sweetwater Seas,+ every couple of years, I drag it up to Maine to play in the Salt,...
It'll pull a consistent 51/52mph at 4800rpms there...
dingbat
The density of saltwater is 1.025 g/ml compared to freshwater's 1.000 g/ml so you're looking at a 2.5% increase in drag at the prop although as Bond-o noted a lot of this is offset by the added bouyancy of the hull.
How your hull reacts to the change in density is a function of the hull design and the boat's displacement.
