Fresh Water Holding Tank Winterization
JohnNC
How do you winterize your holding tank?<br />Drain and add an additive?<br />Leave alone and add an additive?
D
DJ
Guest
Re: Fresh Water Holding Tank Winterization
JohnNC,<br /><br />Use the RV type anti-freeze. Mix it according to directions, with fresh water, and make sure that the solution gets all the way down to the lowest points in the system (read-flush the head and run water into the bowls).
Capt Ken
I'm not reccomending this but I've watched several boat owners over the years go buy cheap Vodka and pour in the water systems. I wouldn't advise this for the holding tank but for the potable water tank it would make for a good party when spring came.
kdmiller8251
Man thats alchohol abuse, cheap or not! HA HA<br /><br />Tallman
