Fresh Water Hookup Not Operational
Thomv
I have recently purchased a used 2009 Powerquest that has a fresh water tank that is not operational. Because I am not familiar with this type of system and no manuals to refer to would anyone be able to direct me to whatever site that would give me any insight as to how it works so that I can try and get operational?
Thanks
coastalrichard
Re: Fresh Water Hookup Not Operational
Your freshwater washdown feature works via a pump which, when activated, draws water from the freshwater tank. Typically, there will be a switch on the dash to turn on the pump. The pump is likely located under the deck on in the gunwale near the tank. Start by checking that the pump is getting power. Could be just a blown fuse. Follow the hose from the nozzle; it'll take you to the pump. Good Luck
