Fried Cylinder - inside view with high 10x magnification
CharlieB
Re: Fried Cylinder - inside view with high 10x magnification
CDI Electronics has the best Ignition Troubleshooting Guide, It covers all ignitions from all manufacturers. Free download, simply find your ignition then follow the easy step-by-step tests to determine the exact problem.
You will need either a DVA meter or a DVA adaptor to use with your meter.
ISSUU - CDI Electronics Practical Outboard Ignition Troubleshooting by CDI Electronics
Old trigger wires can be a problem if the insulation is cracking and falling off, moisture gets to the fine wires inside and they corrode and begin breaking . Sometimes leaving but a few hair fine wires to carry the current, not enough to trigger the switchbox.
Because of that NO RETURN on electrical parts, you want to be SURE to test and retest again before spending a large amount for a part only to find it did not cure your problem. Follow the instructions in the CDI Guide, repeat all tests to verify your findings before ordering parts.
