I need to change my 3 aluminum blade prop 13.5x17 to a 4 blade prop. This prop used to be 15x17 but I cut it myself for WOT tests. The reasons for changing to 4 blade: Engine setup is 3 1/2 inches higher than where it should be. Cavitation plate is 6 1/2 " higher than keel. However, engine platform has a setback of 36" which allows to set engine 3" higher.
Concluding, I need more grip. I only used the boat to idle in canals and to cruise, not top speed.
Johnson 130HP V-4 operates between 5 and 6K rpm. Currently WOT is 5600. Still 400 rpm to go up.
Currently at WOT 5600rpm 32mph. Cruise at 4000 rpm 22mph, 4500rpm 26mph. Large and heavy Boat: Renken 20', V-hull cuddy cabin, 2840 lbs.
Any suggestions in what size prop should I use?
Should I go higher in diameter to get even more grip and reduce pitch?
I was thinking 14x16 but think rpms go lower.
How about 14x15? I saw Amita 4 in 13x15. How about Michigan Vortex? Budget goes for a used SS.
