From push/pull steering to Tru Course steering
Redrig
Master Chief Petty Officer
Hello ,
Quick question . I have an electric shift - 77 boat and it currently has a push / pull steering setup .
A guy has here locally has a tru course that will fit my boat for 30 bucks and it moves freely and looks to be in great shape , my question is. ....
Are all upper units / intermediates set up for Tru Course ? Can I simply just install this to the intermediate and it will work ? Or is there something internal that I would have to add to the upper to use the tru course ?
plugging the hole from the current steering is not a big deal , I am currently doing a little fiberglass work to her and adding a ski locker.
Thanks in advance
southkogs
You probably have the gear on the front of the upper, but the worm wheel up in the top of the upper is probably missing. I think that's the difference (though I've had one upper without the steering gear on the front).
Redrig
I remember when I had my outdrive apart , there was a gear up at the very top of the upper. Basically the gear went around the shaft for the oil dipstick, is that the one you are referring to ?
