Front bow seat removal
Gansen
Any ideas how to remove a seat cushion when its bolted from inside fiberglass? Planning on replacing wood, cushion, and vinyl.
ajgraz
Can you get to the backside by reaching your arm inside the storage area and then up?
kcon
If you can't fit your hand behind there by route of going through that open hatch space, I'd say your best bet might be to drill the bolts out, you can likely catch whatever's behind (like the bolt nut) when if falls into that open space in that compartment, assuming there's any amount of access between them.
Gansen
Couldn't reach the bolts. Moved to plan B. It worked.
i would just pull....the rotten wood will crumble apart. then go from there.
GA_Boater
How are you gonna reinstall the newly upholstered seat back?
Gansen
Decorative pieces are going to have velcro. Going to use the expandable sheetrock screws. Then they are easily removable if needed.
AShipShow
Just out of curiosity... what is an expandable sheetrock screw?? lol..
Is it the same as a drywall anchor?
kcon
Instead of using sheetrock anchors checkout beauclips, they're cheaper, way easier to install, meant for this application, and make it far easier to maintain your upholstery down the line, way more rigid than something like Velcro too.
Woodonglass
Are you planning on doing your own upholstery? If so, there a a lot of good experienced upholsterers here on the forum.
A similar product to use for panel attachments are Plastic Double Headed Christmas Tree Clips
Gansen
Thanks Woodonglass! Yes we are doing the upholstery ourselves. First 10 pieces completed today. Ran out of time to sew the other pieces.
Woodonglass
Very nice stitchin, What machine are you using? Are you or the Admiral doing the stitchin'?
look forward to seeing the finished pieces.:rockon:
Gansen
Using my mother in laws Janome 6600. My husband and her are sewing the seats. Great bonding time for them! I'm just along for the ride. I've always wanted a ski boat. My husband has always said no. When this project boat came up for sale we compromised and got a ski boat.
Woodonglass
I believe that machine has a built in dual feed attachment. That's basically a "Walking Foot" feature. Do you know if they are using that? If not they should and also be using the Longest stitch possible. When sewing vinyl the fewer holes punched in it the better. Also I think they can get a #19 needle for it and if so they can use #69 Marine Thread which would be ideal. PM me with your phone# and I'll be happy to talk with you about any questions you might have about the process.
Gansen
Woodonglass. Thanks! My mother in law has thankfully sewn with vinyl many times. Her machine is quite fancy. Hit a button and it automatically reverses and cuts the thread.
