cheburashka
- Joined
- May 28, 2005
- 715
This is in reference to a Mercruiser 140, early '70s vintage.
I'm new to this, and I'm learning. Learned a big one today. I thought I had drained the water from the entire system by pulling the water hoses on the outdrive, but it appears that I didn't drain the block. We had a two month hard freeze here. When I started the engine today there was water everywhere. Preliminary examination shows two freeze plugs on the port side of the block are completely out of their holes. I've replaced these (they're accessible with the motor installed) and got it running again, but discovered that I had a broken flange on the lower thermostat housing. I've ordered new parts for the thermostat housing--it had been welded once in the exact same place and I'm thinking maybe the engine had been through a hard freeze before. I've checked, and the oil is still transparent, so I don't think there are any internal problems, but I haven't run it enough to really know.
Main question--is there any chance at all that it can be saved? Secondary questions-- Are there other water passages that could have cracked? I know the freeze plugs aren't intended to be a cure-all for fools like me who don't drain their blocks, but is it possible that the freeze plugs and the t-stat housing took up all the force of the freeze leaving me with a block that's still usable? Third question--are there other freeze plugs that I should know about that have probably blown? Fourth question--how can I be sure that I've solved all of the leak problems (assuming it can be done with the engine in the boat) before I put it back in the water? I've heard you can use compressed air, but I wouldn't know how to pressurize the system.
Thanks for any help you can give me. And yes, I know it was a stupid thing to do. Rest assured, you can say nothing that will match the cold glare I get from my wife, who asked me to have the marina winterize the boat.
