Frozen engine
bruceb58
Honorary Supreme Mariner
Re: Frozen engine
Bruce, If I just unbolt the engine block from the engine mount then I should be pretty close right.
Pull the lag bolts out that hold the mounts to the stringers. That is the easiest way.
Squab
Re: Frozen engine
Just afraid of pulling lags because they are most likely totally in the wood and if I pull them out they will never fit right again.
Re: Frozen engine
Ayuh,.... ONLY if the wood is Rotten....
The mount to block bolts Ain't the way to do it....
