PierBridge
- Joined
- Sep 3, 2004
- 625
I noticed that my prop shaft has a slight bend in it and after doing some research found that it is bad too run that way.<br />Well I need a special tool to remove the bearing carrier assembly in order to remove the shaft.<br />Anyone know where I can find one of these tools? It is for a Merc '89 25hp. The tool number is 91-93843--1. Or any tips on getting this thing off. I tried using the thrust hub assembly and a vise grip and ended up breaking off one of the "lips" on the carrier And Yes I do realize that it's left hand thread <br />I do have a manual and also access to an online service manual. According to the service manual, I need a special tool that locks onto the carrier assembly (castle nut looking thing). I did try reversing the thrust hub, however the thrust hub isn't sided it's round, so I tried using a vise grip and rubber mallet. That didn't work. It didn't budge. I followed the manual which says to remove three screws from inside the shaft housing and then unscrew the carrier (left hand thread). I don't know, I'm about to give up. I broke off one of the lips of carrier. Anyone know how much (labor)it would cost to take this thing off?
