Re: Fuel and Oil Mixture
if it hasn't started in a few years it might be a good idea to take out the plugs and squirt a little oil into each of the cylinders and let it sit over night and then the next day squirt a little more oil in each one and pull the engine by hand a few times if it is electric start, if its pull start just give it a few slow pulls to circulate the oil a few times, this is the minimum I would recomend if it turns over and starts well it would probobly be a good idea to check/replace the impeller, lower oil, spark plugs, carb clean basically give it a decent tuneup....good luck
