freetime99
Thread starter- Joined
- Sep 11, 2007
- 129
60hp 3cyl. - have replaced all fuel lines, new bulb,new filter. Engine will idle for 3 minutes, then dies out. Will run at any speed if you pump the bulb continuously. VRO had new kit installed a few hours ago( oil side capped off).Carbs had rebuild 20 hours ago. Is the Pulse Limiter possibly the problem? Engine runs smooth up thru WOT if you pump the bulb. Any suggestions ?
