Fuel consumption on 21 foot Cabin boat with merc 4.3 or 5 Litre
45Auto
Re: Fuel consumption on 21 foot Cabin boat with merc 4.3 or 5 Litre
QC said:
The one thing not mentioned yet here, and it will start a whole bunch of other carp for sure, but theoretically (yes theoretically) all throttled (Otto Cycle) engines are more efficient at more open throttle settings.
Basic thermodynamics there. It?s obvious if you know enough to understand a p-V diagram, not very intuitive otherwise. That?s why they?re trying to develop ?throttle-less? induction systems by controlling the valve lift for spark ignition engines. Unfortunately, very few boaters seem to understand it.
It's the reason your car gets better MPG in overdrive than in high gear at 70 MPH (or any other constant speed) on the interstate. The engine has to deliver the same amount of power in overdrive as it does in high gear to cruise at 70 MPH. When it shifts into OD, the engine RPM must drop to stay at 70 MPH, although power must stay constant. Since Power=Torque x RPM, the engine must increase it's torque output to maintain the same power at the lower RPM. Only way to increase it's torque output is to open the throttle more. The bigger opening minimizes pumping losses so it takes less fuel to deliver the same amount of power.
In simple terms, with the butterflies cracked open under part throttle, the intake manifold is below atmospheric pressure. There is a partial vacuum in the intake manifold. That?s why you can use a vacuum gauge to diagnose problems with your motor. This vacuum is trying to pull the piston UP when it needs to go DOWN to pull in mixture and fill the cylinder. The extra fuel required to generate the power needed to overcome this part throttle vacuum reduces the efficiency of the engine. As the throttle is opened wider, there is less vacuum. The engine is more efficient because not as much extra fuel is needed to overcome vacuum losses. At full throttle, there is essentially no vacuum in the manifold.
There?s a basic explanation of p-V diagrams here:
http://www.grc.nasa.gov/WWW/K-12/airplane/pvtsplot.html
and a basic explanation of a part-throttle Otto cycle p-V diagram here:
http://www.mechadyne-int.com/vva-reference/part-load-pumping-losses-si-engine
We talked about a lot of this stuff in this thread a few years ago:
http://forums.iboats.com/showthread.php?t=225803&highlight=secrets
QC said:
So, also theoretically, if all other things are equal (they never are) the smaller displacement engine would be more efficient at the same boat speed.
If they?re geared and propped the same, that?s true. The Stingray test you referenced did exactly what you described above. It provided a good example of why you don't want to gear your big displacement engine like your small one. You want the big displacement engine to be turning slower than a small one at any given speed to take advantage of it's superior torque. Even though it?s turning at a lower RPM, it is still required to deliver the same amount of power to maintain the given speed, thus it must deliver more torque. If the big motor is geared so it?s turning slow enough, it can easily require a bigger throttle opening than the smaller motor to flow the same amount of air required to meet that power requirement. Thus it can have lower vacuum losses and be more efficient.
If they?re geared the same and both motors are designed to deliver the same max power, like in the Stingray test you referenced, I would expect the smaller motor to always win. Since they are going the same speed, they need to supply the same amount of power. The motors are turning the same RPM, so they have to produce the same amount of torque to produce the same power. But since the bigger motor has more AVAILABLE TORQUE (that?s why it can accelerate faster if you use full throttle), it must use a proportionally smaller throttle opening to limit the amount of torque delivered, thus making it more inefficient.
It?s only interesting when you compare different motors built for the same purpose with gearing/propping optimized for each. The Stingray test you referenced used a 30% bigger motor that made the same peak power as the smaller motor. It would have been designed for a heavy cruiser, not the performance boat they used it in. The article implied this in the last paragraph, where they say:
If we want to pop a heavily loaded cruiser on top with a minimum of fuss and strain, the big-block is the answer.
I would guess that the bigger motor in their test had a higher torque curve in the lower RPM range that was wasted in prop slip upon acceleration with the 21? prop they used. As discussed above, the higher torque curve required a smaller throttle opening (which decreased it?s efficiency) to deliver the same amount of power at the same RPM as the smaller motor. A better choice of motor for a comparison with the 300HP 350 would have been a properly geared/propped 385HP 454. It would have some of the torque moved towards the higher RPM range and required a bigger, more efficient throttle opening at lower RPM, but would also have had substantially more power at high RPM.
45Auto
smokingcrater said:
speaking overall efficiency only, an engine running 11:1 at WOT will never be more efficient than the same engine running 15:1 at cruise. You are dumping unburnt fuel out the exhaust at WOT, which more than makes up any efficiency drop you get because of throttling.
Pretty broad statement there. Any documentation anywhere that supports it?
If you're talking engine efficiency only, it could go either way. If you're talking overall efficiency (which is MPG) in a boat, the cruise condition will always win since drag increases exponentially with the speed of the boat and dominates the equation. Losses due to drag are orders of magnitude greater than any gains or losses due to A/F ratio, unburnt fuel, throttling, etc.
mattb1974
I call BS on this. Everyone knows in order to get the most power and fuel economy you need to;
1) Adjust your Prenunculator Valve 3 clicks
2) Switch to High Performance turn signal bearings
3) Loosen the boats MAIN BOLT a little
45Auto
An excellent example above of a boater who understands Boating Science (BS)!
Only a few clarifications are necessary:
1) Adjusting the PRE-nunculator Valve by 3 clicks will only increase the turbulence of the hydrodynamic toroidal vibrillator. Generally a 3 click relief of the POST-nunculator valve will allow your brembulator to coalesce at a higher rate.
2) The High Performance turn signal bearings are only required on newer Alpha drives. Older Alphas, Bravos, and all Volvo Pentas may use the much cheaper Premium Turn Signal Bearings with a negligible performance loss ? usually less than one gluon per electrostrahnmyer.
3) Loosening the boat?s Main Bolt (either a little or a lot) can usually be most easily accomplished by a liberal application of any adult beverage.
