fuel cooler
letsgo19
Does a mercruiser 305 carbed engine have a fuel cooler?It"s a 2004.I can"t find one but i"d like to make sure for winterizing purposes in case i should need to drain it.
Gary H NC
Re: fuel cooler
Never seen or heard of a fuel cooler..
It may have a power steering cooler and those do need to be drained.
dubs283
Re: fuel cooler
mercruiser cool fuel system uses raw water to cool the fuel at the pump to help prevent vapor lock
yes power steering cooler needs to be drained if not flushing with antifreeze
in any case, if equipped with a cooler of any kind, it will be located in-line with the raw water intake hose prior to the t-stat housing
