bowhunter83
Thread starter- Joined
- Jun 27, 2009
- 22
I have a '91 Evinrude 48SPL......its a 2cyl. The motor starts and runs rough at idle. I have good spark. And the No 1 Cyl is the prob. When I spray fuel out of a bottle into the No 1 Carb, the rpm's kick up and it runs fine, but when I stop spraying the rpm's cut down and it runs rough again. There is fuel getting to the carb because I've checked the drain on the bowl and the bowl has fuel in it, but its not getting into the cyl. Both cyl have intake compression b/c I can cover the carbs with my hand and feel the vaccum. AND both cyl have good internal compression, they checked out with No 1= 120psi and No 2=110psi........I just rebuilt the carbs a few days ago because it was doing the same thing before I rebuilt them......when I had them apart I checked the pickup tube and it was clear and unobstructed.........is this a low speed needle valve out of adjustment or something else?????? And when I took the carbs off, I checked the reed valves and all of them seem to be working fine and in great condition...Any help is greatly apreciated
