Fuel dripping from carbs...
dfrants
Picked up a very used rebuilt Merc 150 xr2, at idle it drips fuel from the carbs, especially the middle one. When I squeeze the primer bulb the carbs fill and don't overflow, It happens while it's running. Compression is 112-115 on all six.
dingbat
Using the primer bulb builds more pressure than the fuel pump.
Either adjust or replace the needle and float in the offending carb
Some of the early V6 motors do not have replaceable floats. Be careful with your floats until you see if they are replaceable.
