findinghomer
Thread starter- Joined
- Nov 7, 2009
- 382
2 bbl mercarb on a 5.7 v8. Boat fires up fine when cold, but it seems to be flooding as it's running. Because when I shut it off , it does not want to restart. I can look down in there and see a pretty significant amount of fuel dripping from venturi cluster ( even has a tiny drip 10 minutes after it's been shut off) into the throttle body, is that normal or is that my problem? I rebuilt the carburetor and changed all the internal components thinking it would fix whatever's causing it. After the rebuild I have the same problem. Any ideas? I Replaced all gaskets, accelerator pump, float , needles/ seat, spring, check ball, one thing I did find out, the schematic shows two gaskets underneath the Jets, the rebuilt kit did not have these, nor did the Old build have them. It did however have 2 steel washers that seem to fit the Jets perfectly, so I used those. Can Somebody point me in the right direction on what I need to look for? I'm almost to the point of just buying a new carburetor. Thanks !
