Fuel dumping into carb...normal?
Maxum88
Ok, I have a 95 mercruiser 3.0LX. I rebuilt the carb, everything seemed good...did the chem dip, gaskets, float, etc. I now notice that when I start the boat the plastic fuel line that goes from the fuel pump into the carb near the top has fuel spraying into the carb. Is this normal? I thought this was just an overflow but it happens on a regular basis. I'm thinking this is also why it's hard to start if I turn in off and try starting it a couple minutes later. Bad fuel pump?
Thanks in advance for your help!
-Tim
HT32BSX115
Re: Fuel dumping into carb...normal?
-Tim
Howdy,
Nope. Not "normal"
You need to replace your fuel pump.
I'll also add that, you might need to change the oil too. You may have some of that gasoline going into the engine too.
Cheers,
Rick
Maxum88
Thanks Rick!
I guess I just needed a sanity check! I haven't pulled it yet to clean it, figured I would try that tomorrow but don't expect it to fix it. Sierra fuel pumps are about $110 and Mercruiser $132. In your opinion, should Sierra be OK, or should I just suck it up and go with Mercruiser (PN 861676A1)?
I'll go ahead and change the oil again and the water/fuel separator while I'm at it!
Thanks for your help!
-Tim
