Re: Fuel economy - 3.0 vs 4.3 on a 19' boat
My 19' is equipped with a 3.0 and I couldn't be happier. The data from boatest.com shows that in my case the 3.0 is superior in economy vs. the 4.3 in the same boat. To be sure in your case, you need to compare Bayliner data since not all boats are the same.
A 3.0 will do anything you want as long as its propped right. I experimented to get what I need and ended up having a SS prop custom pitched. If I told you my fuel usage and speed you wouldn't believe me. Getting on plane has never been a problem, even with 8 people on board.
If you are a speed deamon, maybe a 4.3 would be better. For sure, you don't want to run any engine flat out all the time. In my case, waves and traffic always keep me at or below 3000 rpm, so I don't think I'm wearing out my 3.0. (28 years old, 1300+ hours and never serviced beyong routine PMs).
In contrast, my son has a carbed 4.3 on a boat only slightly larger, so got some data there too. I wouldn't want to run either at trolling speed. Both vibrate a little much for my liking, plus i don't believe in running at idle hour after hour. My 9.9 kicker serves many purposes and when trolling you can't even feel it. I wouln't be without it, even if i didn't troll.
