Fuel fill question
Capt. Stabbin
I'm ready to install my new 16.5 gallon Tempo below deck gas tank and I have a question; will gasoline travel to the tank unimpeded if the fill hose makes a bend up and then down to the tank? This tank was the only stock tank that I could find that would fit.
Boatist
Re: Fuel fill question
Capt.<br />As long at the tank input is below the the level of the fill then it will fill but can be slow if has a lot of up hill or if the tank input is near the same level of the fill cap. You must have a clear vent hose.<br />If the vent has the same up hill to the tank you will end up having a fuel spill and slow filling tank.
Capt. Stabbin
Ah man.... my cover is "blown"! Seriously, I'm not the original Capt., although we do share the same "passion" for boating............... I was wondering when someone would catch that! LMAO
D
DJ
Guest
You will have trouble filling the tank with the fill hose routed as you mention.<br /><br />The up and down routing of the fill hose will cause an air lock. Been there-done that! :eek:
ChrisMcLaughlin
I wasn't going to say anything, but Capt. I think you have your affairs in arrears!!!
bomar76
I had a hilarious post about what would happen that I deleted on further review.<br />Use your imagination.<br />Anyway, doing what you propose could cause no end of troubles.
Capt. Stabbin
Thanks for the responses. I think I will route the fuel fill on top of the console and it will have a direct line down to the tank.I saw an old Aquasport that was rigged this way. My original setup is a fill on top of the port gunnel running down 2 feet or so and then a 90 degree angle to the tank. Time for a Stabbin Dog..............
