Fuel Filter change and maybe screwed something up.
simcole
Hey everyone,
Again, this is my first boat and first year owning it. I am in the process of changing out your basic parts to do yearly maintenance on it (oil, fuel filter, spark plugs etc). I have ridden on it about 7-8 times prior to my recent fuel filter change. I went to West Marine to buy a replacement fuel filter but they were out of stock. I called another local shop, but he said I'd need to bring it in to match it. I took my old filter off which had no markings on it (brown dented to hell and old), and I took it to my local shop. He matched it with a "Sierra 7789" filter but also didn't have it in stock, but could get it by the end of day. 6 hours later, all the while my fuel filter was off my boat, I head back to put the new one on. I fill it full of gas to prime it, and oil lube the o-ring. I spilled some of the fuel (1/4-1/2 cup) into my catch pan while I was installing it on the boat. I turned the key 3 times pausing 15 seconds or so between turns to fill it the rest of the way. Finally I start the boat and after a unusually long crank it starts. Previously it takes <6 seconds to start, this time it took about 12-15.
I took it out on the lake today and it started surging any any RPM. It didn't always happen, and when it surged it dropped 50-100 RPM and I could hear the motor pitch change. When it surged it happened for 20-30 seconds at a time, then it would speed back up for another 20-30 seconds. I noticed it much more around 3000 rpm than at other rpm. Prior to my filter change I don't recall the boat surging at all.
Did I screw something up? I saw the fuel test sticky, but maybe since I'm new I just over looked something?
When I dumped the old filter into a gallon bag I managed to get a bunch of engine dirt into the bag as well, so I'm not sure if the filter was dirty or not. There was no water in there.
skydiveD30571
Re: Fuel Filter change and maybe screwed something up.
What is your engine's full model number or serial number? That is necessary to find out the correct water separator you should have.
simcole
Volvo Penta 5.7 GI PNCACE
My engine also has the fuel pump directly on top of the fuel filter. Which is image B in this PDF.
Europe website shows Sierra 7852, but I can't find that anywhere else.
skydiveD30571
The service manual for your engine says part number 3851218-2. The Sierra equivalent is part number 18-7789 and is available right here on iBoats.
Start with installing a fuel filter that you know is correct for your engine, then see what happens.
