Re: Fuel Filter,Water separator,and Fuel pump set up.
OK BT Doctur, I got now, Yes this is the way I bought the boat, I would like to put it back the way it should be, I wonder if the fuel pump is pumping enough to the carb strong enough, I am going to compare pressure while I am at it too, I have a feeling that the engine and or stern drive were replaced, because according to SEI Drives I should have a ALPHA ONE Gen 1,sterndrive, the S/N says it's just an alpha one, Yes it only has two bolts not four, The Alpha one has two. The gen 1 has 4.????? This is a new thread, some one had asked about so I posted how mine was set up,Justin
Thanks again boat Doc for all your help and Info. I will deffinitly put it the way it should be, I do not know the full history of the boat and some things are just not adding up which makes things harder, but with your guys help we do figure it out
.................................Thanks again!!................Pat
