What does the sensor sense? Mercury Marine 35-18458Q3 replacement parts - iboats
drtyTshrt Seaman Thread starter Joined Jan 15, 2013 Messages 58 Apr 8, 2013 #1 What does the sensor sense? Mercury Marine 35-18458Q3 replacement parts - iboats
Fun Times Moderator Staff member Joined May 16, 2009 Messages 9,459 Apr 8, 2013 #2 Re: fuel/filter water/seperator with sensor Water! Item #37, http://www.mercruiserparts.com/Show...=572&bnbr=100&bdesc=FUEL+PUMP+AND+FUEL+FILTER
drtyTshrt Seaman Thread starter Joined Jan 15, 2013 Messages 58 Apr 8, 2013 #3 Re: fuel/filter water/seperator with sensor Uhh, thanks. Does it sound an alarm or something?
Fun Times Moderator Staff member Joined May 16, 2009 Messages 9,459 Apr 8, 2013 #4 Re: fuel/filter water/seperator with sensor Yes it will if it senses any water in the filter that is resting at the bottom of the filter.
drtyTshrt Seaman Thread starter Joined Jan 15, 2013 Messages 58 Apr 8, 2013 #5 Re: fuel/filter water/seperator with sensor Thanks. I asked around and was told I can ground it out to test if the buzzer works.
Fun Times Moderator Staff member Joined May 16, 2009 Messages 9,459 Apr 8, 2013 #6 Re: fuel/filter water/seperator with sensor Yes, grounding is a way to test to see if the warning system works correctly.
drtyTshrt Seaman Thread starter Joined Jan 15, 2013 Messages 58 Apr 8, 2013 #7 Re: fuel/filter water/seperator with sensor Thank you again.
