Fuel Filter
tommymoe2002
1996 Force 120, can I replace the clear fuel filter which the old one is a NAPA with a clear purolator from my local auto parts store. My friend said that the new filter's paper would fall apart in the filter because of the oil gas mixing (2cycle oil). Also, do the spark plug wires come out of the coil packs or are they just one unit? The old owner never change the spark plug wires. I just got this boat over the winter and want to give it the best tune up before going out inthe water. Thanks<br /> Tom
JB
Re: Fuel Filter
Hi, Tommy.<br /><br />I recommend that you use a seperating filter intended for marine use with mixed fuel. Though I don't think the mixed fuel will cause an automotive filter to "fall apart", there are other considerations that make auto parts unsuitable for marine use.<br /><br />Good luck. :)
rickdb1boat
Re: Fuel Filter
Amen JB! This one is cheap enough and will get the job done. I would highly recommend it on your Force Motor.. <br /><br />web page
roscoe
Re: Fuel Filter
If you replace the sparkplug wires, make sure you use wire core plug wires, NOT resistor type carbon fiber plug wires.
tommymoe2002
Re: Fuel Filter
Roscoe,<br /> Thanks, but how do they come out of the coil pack? By twisting then off?
roscoe
Re: Fuel Filter
They should just pull off. It may help to try to pry them off.
