Fuel Filter
marcg
I just changed my fule filter and oil in a 2001 Merc 5.0. Once I fired it up, it ran for a few seconds, throtleing up and down on it's own, and then cut. It cranked againg, for about 5 seconds, and won't crank again. Any suggestions?
180shabah
Re: Fuel Filter
First lets clear up some terminology. What do you mean it cranked for five seconds then wouldn't crank?
Crank = engine spinning(powered by the starter)
Was the engine able to spin?
Re: Fuel Filter
Ayuh,...
Is it turning over, on the starter,+ Not firing/ running,..??
If So,...
Did you prefill the fuel filter,...
If Not,...
It ran outa Gas,+ needs priming...
marcg
Re: Fuel Filter
That did it. It cranked right away and runs fine. Thanks.
