Wass Bay Doug
- Joined
- Jun 19, 2004
- 7
My Johnson 60 hp 71 electric shift has been running like a clock and still does at slow speeds. However recently it started running for about 30 seconds at high speed then fadeing. If I continue to sqeeze the bulb by hand on the gas tank it will keep up speed. <br /><br />I did the obvious, change gas lines from the tank, tried different tanks, replaced the fuel pump and looked for leaks. <br /><br />I am now at a loss, last night I put carb cleaner into the motor but am not optimisitic. Any ideas where I could look for this problem?
