fuel gauge issue
bakerjet
my fuel gauge does not read squat!:p is there a test i can do to see if its the sender or the gauge? its a faria gauge, thanks
Rocky_Road
Re: fuel gauge issue
If you remove the lead on the tank sender...and connect it to a good ground...Key in the "RUN/ON" position...the gauge should peg right past full.
If it does, then your gauge and wire to the gauge, are fine.
