Is the fuel gauge just measuring Ohms from the sender?
I was having a problem with my dash fuel gauge not going to full even though the sender tested OK. I bypassed my dash fuel gauge to hook to a NMEA 2000 network and read off my Lowrance fish finder fuel management option which worked fine and showed perfectly 100% full when the tank was filled.
I later discovered that I had a charging system issue as well. So I did have a lower than usual voltage while running. Could the low fuel gauge reading been related to the charging system issue?
Could low voltage give me a faulty reading on the dash fuel gauge?
I did still have the low fuel reading even with a fully charged battery, but now I wonder...
I know the answer would be to hook the dash gauge back up, but I did kind of physically abuse the gauge to force it to the full mark once I knew the sender was OK, but before I knew I had a charging system issue. I also can't just replace the fuel gauge because the dash is a 1 piece modular unit.
