crashpro
Thread starter- Joined
- Apr 10, 2011
- 40
I have a 1987 Astroglass bass boat that the fuel gauge quit working. It has a 22 gallon built in tank. It worked fine at the end of last season, worked intermittently Feb. and March, and now has quit working all together. We found online how to check the gauge and the sending unit. Both tested good. We then checked the wiring and there was continuity (no broken wires). We also cleaned all of the terminals. We even ran new wires directly between the gauge and sending unit and it still didn't work. Gauge has 12.95 volts coming into it and we read 7.94 volts between the ground and pink wire with a 7/8 full tank, both at the gauge and sending unit. Removing the pink wire from its terminal on the gauge, the terminal reads 10.45 volts to ground. Individually, all components check as they should, but as a system, the gauge always reads "E."
