Fuel guage
foodfisher
'86 Bayliner Capri 19' bowrider-Fuel guage has broken needle and burnt windings so a repair is out of the ?. Having a real hard time finding a replacement. Will any likesized guage work, or does the sender have to be replaced also? It's in a 32 gal. aluminum under deck tank. The guage has a three pronged connector with an xtra wire for the light. Thanks
Silvertip
Re: Fuel guage
Try here: greatlakesskipper.com
They have a large number of new-old stock gauges and are exceptionally well stocked with older Bayliner/US Marine stuff. Failing that, any fuel gauge will work but you will likely need to cut off the connector and add ring terminals to fit the replacement "generic" fuel gauge. No big deal with that. You shouldn't need to change the sender as they are generic as well.
