arriva2001
- Joined
- Feb 15, 2015
- 64
Hi
im looking to install a seachoice water separating fuel filter on my boat (to feed my Force 150). The fuel line coming from the tank has a 3/8 inner diameter. So I bought a brass barb fitting also with a 3/8” inner diameter.
I tried slipping the hose over it, and it’s near to impossible to fit it and when I do, the hose looks very stretched and as if it may fail early.
my questions are: should I be using a brass fitting with an outer diameter of 3/8 to fit the hose better? And if I did, wouldn’t that cause the fuel to be restricted? Is there any restriction here that could cause a lean issue? The filter supplies 25 gallons per hour so that seems sufficient.
if I’m supposed to use the 3/8 inter diameter fitting to match the inner diameter of the hose. Is there any concern that the hoses are being stretched too much or could fail?
