Fuel hose leak johnson 55
maineiac5586
Hi working on 1987 commercial 55 hp johnson tiller. Can't get these hoses that go from the plastic t fitting to the carbs to stop leaking. I tried the correct fuel line size. Seems worse when using zip tie to secure the line. Anyone have any tips?
saltchuckmatt
Check the fitting, it might be cracked. If the right size hoses are used it's hard to have a leak.
