Re: Fuel in the Bilge
I have the exact same problem. 150 hp mercury outboard. I took off filler tube, and checked, no leaks. Took off tube from tank, to primer bulb, and replaced. That was o.k. also. Boat is 2002 tracker, with a 40 gal plastic tank. It is under floor boards. How do you check the tank for leaks. I really hope it is some other problem. I just can seem to imagine, that being only 6 year old boat, that the tank is defective. There is a possiblity that a squirrel may have caused damage, since found a nest this past winter. How could a sending unit cause a big leak. My fuel gauge was not working, but the seal seems to be tight. I still have a lot of gas in the tank. Should I fill it up with more gas, and see if it leaks. (OPEC would like that).
