w317chester
Thread starter- Joined
- Jul 7, 2010
- 54
Okay so i'm almost there with my newly remanufactured 6.2L MX MPI (serial number OM317417) engine but i've got a fuel issue. So my first fuel issue was my fuel pressure was too high. The engine would idle fine but if you gave it throttle it would want to die (guess it was running too rich and flooding the engine). We measured the fuel pressure and it was approximately 80-90 psi and then we replaced one of the fuel pressure regulators (the one down on the cool fuel cooler and next to the fuel pump). After we replaced that regulator now my fuel pressure is too low (engine want stay crunk). Fuel pressure is around 10-20 psi. My fuel pressure should be 43 psi.
Some things i've done/some thoughts:
1. I have brand new water separating fuel filter
2. I have brand new in line fuel filter
3. I siphoned all (or at least as far as the gas pickup could siphon) old gas out of my tank and replaced with fresh gas
4. Both fuel pumps are running (yes there are two: one coming from the gas tank and then the one next to the cool fuel system that delivers fuel to the fuel rail)
Any help is much appreciated!
