OK Guys, <br /><br />I've been fighting a minor problem on my boat since I bought it.<br /><br />If I cruise around in idle too long, or if I sit at the dock idling too long, the motor will die. It will run low on fuel, sputter, and die.<br /><br />If I reach down to pump the fuel bulb, it starts running again, just fine, and will run again for several more minutes.<br /><br />Now, if I am running high RPM's, I have no trouble at all. I've run for 25mins+ at WOT, and it ran fine the whole time, never ran out of fuel.<br /><br />But, when at low RPM, it will run the fuel out of the bulb/line, and I have to prime it to keep it going.<br /><br />Any ideas?<br /><br />New Bulb<br />New Line<br />Pump should be good (works fine at High RPM's)<br />New Filter<br /><br />What else?<br /><br />Let me ask you this:<br /><br />My Fuel Primer Bulb is a good 4ft away from my engine, tucked away inside of a compartment. I have noticed that 99% of primer bulbs that I have seen are within 12" of the engine itself. Could this be a problem? The fuel hose does make a few weird turns in the compartment (to make it all fit). I did notice that if I set the primer bulb in a horizontal position, I have less trouble (versus it being vertical). <br /><br />I can get pics of the setup if necessary.<br /><br />Thanks!<br />Shawn
