ringmaster
Thread starter- Joined
- Aug 23, 2007
- 125
im working on a 1987 celebrity with a mercruiser 175 and alpha 1 outdrive. the guy that brought it to me said it needed a ignition moduel well that wasnt the case found the wires un hooked. the problem im haveing is fuel related. i took the carb apart and cleaned it plus a new filter checked all the lines everything was clean when i put it back together. it will start up fun but wont idle unless i work the throttle to keep it running. would that be caused from a weak fuel pump? i just cant track down this bug.
