xxturbowesxx
Thread starter- Joined
- Apr 20, 2008
- 494
I have a 1994 xr4 when I'm running shallow at idle with the motor trimmed pretty high fuel runs out the bottom of the cowling. I know if the motor is trimmed all the way up the fuel will run out but it seems like this shouldn't happen.
Also i should mention the boat has a running problem wont reach full speed and wont plane normally. The boat will run reasonably fast then slow down. I just bought the boat today and used this to work out what turned out to be a bargain.
Should i remove the nuts from the bowls and pump fuel out? Ive pulled the carbs off my 1990 mariner 150 and they are the same so I'm not afraid of a rebuild if i have to. I pulled the fuel filter off and it was deteriorated very badly and i think part of the element was sucked into the bowl of the carbs.
