hardwater fisherman
Thread starter- Joined
- Mar 19, 2010
- 1,725
Early 80s 40 hp. Serial # 7207752 Canadian made. When tilted fuel runs out of the carb throat. I know some fuel dripping is "normal". If I pump the primer bulb with the motor tilted it pours out. If I prime it while the motor is down it fills the bowl like it should and the the bulb gets hard and the carb bowl stays full ... Then if I tilt the motor up fuel drips out quickly. Also running at WOT the motor surges a little. And if in a high speed turn the motor really surges. The motor had the carb rebuilt in a local shop back in 2017 and I have had no issues until now. I think maybe a float or float needle problem? It has the float bowl on the side of the carb which I do not have any other like it. Also I added electric start to it and the carb is hidden behind everything. Any help would be nice thanks.
