Manipulator
Thread starter- Joined
- Apr 11, 2005
- 743
I have OMC 5.7 L GM and I cleaned out the screen filter in the carb (Rochester Quadrajet). The thing is, when this was done before the previous owner used a vice grip on the compression fitting that goes into the carb. He tore the hell out of it and I had to remove the carburetor to get it lose. The tube needs to be replaced and the compression fitting is in sorry shape. I managed to get it all together and tighten it up. It was leaking and I had to tighten it up real good. Now it does not leak but it would never come off with out removing the carb again. The screen has been cleaned last season and it had rust and other crude in it again when I clean it this time. The other filter is fairly new (canister by the fuel pump). My question is can I add an inline fuel filter from the hose that comes from the fuel tank and goes to the fuel pump? The hose that goes from the fuel pump to the carb is steel tubing so that won't work or will it? What if I cut the tube and ran rubber fuel hose up to the carb? <br /><br />I have a canister filter but for some reason bits of rust and crude make it to the carb screen. I figure if I add an inline filter this will help prevent particles from getting to the carb screen. Whole point is because I do not want to remove that compression fitting from the carb again to clean the screen. <br /><br />I guess most of you would say "easy solution, buy a new tube with new compression fittings". Problem is where would you find it? I do not have a flare kit to repair one I have.
