Re: fuel line disconnect for winterizing
Do NOT disconnect the fuel line on an oil injected 2-stroke and then run it out of gas! As the gas is running out, oil is still pumping full tilt. That fills the fuel lines with oil (because there's no gas being pumped for it to mix with), and when you pump the primer bulb in the spring, the oil in the lines goes into the carbs first and settles to the bottoms of the bowls. It doesn't harm anything, but it's about impossible to start them. I run into this every spring with people that bring in motors that won't start after they winterized it themselves. That's true for both Mercury and JohnnyRude motors. Exceptions would be most Japaneese motors that inject the oil straight into the motor rather than mix it with the fuel. Run the motor long enough for stabilizer to get into the entire fuel system including the carbs. Drain the carbs if you like, but in the spring you'll be pumping striaght gas into the carbs and that's not good either. It's best to leave stabilized gas/oil in the carbs on such motors.
