handle
Thread starter- Joined
- May 7, 2012
- 104
How often do you replace your fuel line? Started out in 08 with new 3/8" Shields fuel line USCG approved. When should you replace it? 1st would you stay with the 3/8" line or maybe go down to the 5/16" size. 2nd I never installed the ant-siphon device, would you suggest that device be installed. It has a permanent tank above deck and feeds a 40hp outboard motor.
