Re: Fuel line
Well, the fittings that the line connects to are less than 1/4 inch in inside diameter and the inlet seats on the carbs only have about a 1/16 hole in them. So, theoretically and probably practically 1/4 would be ok. EXCEPT: If you have a long run of fuel line from the tank to the fuel pump, internal resistance will slow fuel delivery. If it is working well now, leave it alone. If you need to replace the line, it would be better to go to 5/16 or 3/8 line. 3/8 ID hose will fit the black plastic inlet screen, but will be loose on the carb fittings and fuel pump outlet fitting. It is better to use 5/16 ID hose there.
