Fuel line?
Buffalo79
I can't get any fuel through my line. I have a line out of tank, to water seperator, to primer bulb. The motor was not getting fuel so I pulled the line, pumped primer and got nothing. I replaced primer bulb, still nothing. Went and got a second new primer bulb, still nothing. All fuel lines are new, and I can blow air back through the line and get air bubbles in the tank. Still the most I can get out of the line is a dribble of fuel if i am lucky. Any ideas?
tashasdaddy
Re: Fuel line?
what motor? what kind of tank? what kind of hose are you using? is separator clogged? what filter does it have in it? 10 micron is what should be there. have you tried by passing everything and pumping directly from the tank? is the arrow on the primer bulb pointing toward the motor, if backwards, will not pump? if after market bulb. point arrow to the ski. is the separator filter full of fuel. when you change the filter, you need to fill it with fuel?
just a start. answer these.
